need help asap
Old Dec 31, 2010 | 07:10 PM
86ztwenty8's Avatar
need help asap
I got the new trans installed, everything else put back in correctly.
pedal feels like theirs nothing there and all its doing when you hit the starter is clunking like the clutch is engaged. the pedal is floating like it has no clutch. It just bouces right back up.
Any ideas?
Old Dec 31, 2010 | 07:44 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: need help asap
bleed, bleed, bleed, and when you're done, bleed again.
Old Dec 31, 2010 | 07:47 PM
86ztwenty8's Avatar
Re: need help asap
i'd love to. but the car wont start for me to do that. When the starter hits it only clanks
Old Dec 31, 2010 | 08:21 PM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
Re: need help asap
You dont need the car to start to bleed the clutch.
The way I did it was make sure the master is full, take a pry bar and pry back on the clutch fork towards the front of the car, then break the bleeder screw open (wait for fluid to and air to come out) then close (maintaining pressure on the fork). Release the fork and allow it to return back to normal. Check your fluid. Repeat about 4 times then you should be good.
Old Dec 31, 2010 | 10:10 PM
86ztwenty8's Avatar
Re: need help asap
now the back end of my slave cylinder is pouring fluid when the clutch is pressed in. How hard is that to replace? Im coming out towards the end of the boot. And got worst while bleeding the clutch. I have a firm pedal now, But it pours out when i hit the clutch,
Im trying to sell the car
should i go new or used?
Old Dec 31, 2010 | 10:14 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: need help asap
With something this vital to your safety and the cars operation, ALWAYS NEW.
Old Dec 31, 2010 | 10:21 PM
86ztwenty8's Avatar
Re: need help asap
How hard is the install?
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
