more help with clutch
Old Jan 1, 2011 | 03:33 PM
86ztwenty8's Avatar
I replaced the transmission in my car. and the slave cylinder cause it went bad and started pouring fluid. Now i rebled it. and the clutch pedal has to be dragged up with your foot off the floor board. and its then when you push it back in. It gets about 3/4 of the way and stops. you have to force it the rest of the way down
Now when i was bleeding. I left the rubber boot out of the master cylinder for the clutch,
Was that defeating the purpose and i need to have that in to prevent air from getting in it?
I need help asap
Old Jan 1, 2011 | 04:53 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Re: more help with clutch
Sounds like a bad master to me, not air in the system. As long as there is fluid in the master cylinder you don't need the boot while bleeding.
Old Jan 1, 2011 | 07:12 PM
86ztwenty8's Avatar
i dont wanna throw that much money into a car. Im not keeping. I need a truck for work and im just trying to get it running.
Old Jan 1, 2011 | 07:14 PM
travis_henry's Avatar
Car: stock car
Engine: 350 Chevy
Transmission: 1.76 powerglide
Axle/Gears: 3.73s
i think a master is only 30 bucks from kragen.
Old Jan 1, 2011 | 07:47 PM
86ztwenty8's Avatar
thats what makes no sense. Its not leaking and its holding fluid? How can that be the issue?
Old Jan 1, 2011 | 07:54 PM
Car: stock car
Engine: 350 Chevy
Axle/Gears: 3.73s
well i had a similar problem on a 89 honda accord i had. the clutch would not wor for crap i tried everything bleeding it and just ended up buying a new master and it worked fine after that.
Old Jan 1, 2011 | 10:41 PM
86ztwenty8's Avatar
im just tired of sinking money into it. I really am
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
