T-56 Transmission Gear change couse of 4.10
Old Jan 4, 2011 | 06:57 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Hi everybody,
I have a 93´ LT1 Trans Am with T-56 and 3.23 rearend.
I did a lot of searching but found nothing helpful, so I hope you can help me, because at transmissioncenter.com I only found info how to swap the drive- and driven gear in a Th700R4...
So I need to know how to change the drive gear in the T-56 (where to open, how to remove the outputshaft, do I have to remove the trans...), what drive- and driven gear do I need and where can I buy them to get the right speed shown for my new 4.10 rearaxle ratio.
Thanks for your help,
Rob
Old Jan 4, 2011 | 07:14 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T-56 Transmission Gear change couse of 4.10
OEM T56's all had electronic VSS sensors. All speedo/gear calibrations have to be done in the ECM tune unless you want to waste money and use a calibration box (dakota, etc.) to do the change electrically.
Old Jan 4, 2011 | 07:20 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Hello Mike,
thanks for that fast reply!
Can you tell me how to do this "electronic calibration"?
Tranks Rob
Old Jan 4, 2011 | 08:53 AM
85MikeTPI's Avatar
You have to reprogram the chip in the ECM. The '93 was still EEPROM based. You can read/post in the PROM/ECM forum if you need assistance with it..
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
jbd1969
Aug 17, 2015 07:06 PM
mizz0313
Aug 12, 2015 06:45 AM
cRoe4
Aug 7, 2015 08:46 PM
