B/W 9-bolt - Limited slip slow to lock and transmit torque
Old Jan 14, 2011 | 08:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
My LS seems to be slow to 'lock' up. I got stuck today on some ice when I was going up a ramp into a parking lot. One tire was on ice, other on pavement, and the damn thing just wouldnt transmit any torque right away. After some messing with it, it did finally lock up and allow me to get in.
Same thing on pavement. Mash teh gas down, and for a second or two, it acts like an open diff, then abruptly begins transmitting torque to the wheel that has traction. Its about 10 degrees F out or so, so I dont know if that has anything to do with it. I do know that the car wasnt driven real far, so teh gear oil was still cold.
Is it just old age, and the cones are worn, or could it be my diff fluid? I cant recall remembering to add teh LS addative. I think I just have standard gear oil in it. Is the addative a friction modifier to stop chatter, or does it also increase the friction between the clutch/cones?
Old Jan 14, 2011 | 10:49 PM
big gear head's Avatar
Re: B/W 9-bolt - Limited slip slow to lock and transmit torque
Probably worn cones. You can recondition it. The additive makes it slip easier.
Old Jan 15, 2011 | 05:56 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Yeah, I guess theyre worn and dont have the tension they used to, so they dont lock up as fast. I'll have to pull the carrier when it gets warm and see if theyre still servicable.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Nick McCardle
Sep 10, 2015 08:36 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
