Changing an Auto Trans to Manual
Old Jan 20, 2011 | 08:18 AM
F1 Bomber's Avatar
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Okay so I have been planning to throw a 350 into my car for a while now, and I found an engine and transmission for $500, however the downside is that my car is a 5-speed and the transmission is an auto. What do i have to do to the auto transmission to make it into a manual?
Old Jan 20, 2011 | 08:57 AM
OneSlowL36's Avatar
Car: 2000 Camaro
Engine: L36
Axle/Gears: GU6/G80
Re: Changing an Auto Trans to Manual
Ok.... so just use the engine and sell the trans.... Or don't buy the trans at all. You can't "make" an auto trans a manual - you can swap them, but all of that is irrelevant if you want to keep your manual trans.
Old Jan 20, 2011 | 09:38 AM
F1 Bomber's Avatar
Okay thanks, wasn't sure if it was possible or not, guess its off to the junkyard i go (sigh)
Old Jan 20, 2011 | 10:47 AM
marc12321's Avatar
Car: 1987 Camaro
Engine: 355 4bbl
Transmission: tko 600
Axle/Gears: 12bolt 3.73
the most you can do is put a manuel valve body in it so you have to shift it
Old Jan 23, 2011 | 12:05 PM
Abubaca's Avatar
I guess I'm not understanding... ....why don't you just take the automatic that you get with the 350, and put it up on craigslist? ....why can't you just use your existing 5 speed with the new 350?
Old Jan 24, 2011 | 11:44 PM
F1 Bomber's Avatar
Well I am planning on doing a few mods to the 350 to give it about 380 horse and 415 torque, and I have been told that even though the 350 will bolt up to my transmission it wont be able to handle that output.
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
