TH350 drop in.
Old Jan 30, 2011 | 04:06 PM
mm1493's Avatar
TH350 drop in.
I have an '82 sports coupe, with a th200. Is a TH350 swap pretty easy with this set-up? it will bolted on to a 350 sbc.
Old Jan 30, 2011 | 04:19 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
Re: TH350 drop in.
should all bolt right up..
Old Jan 30, 2011 | 04:26 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: TH350 drop in.
You will need a TH350 conversion kit fro summit or Jegs so the torque arm has a mounting point. If the TH350 your using has the 6in tail shaft the drive shaft will work.
http://www.summitracing.com/parts/BMM-30299/
85 Jimmy
Sep 30, 2015 07:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
apie2546
Sep 24, 2015 12:27 AM
sahlomonic
Sep 20, 2015 07:15 PM
89newfun
Sep 16, 2015 09:28 AM
