transmission load is making my engine stall?
Old Feb 16, 2011 | 03:49 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Transmission: 5 speed
its an 86 305 tpi camaro with a 700r4. when in park the idle is high. around 1200. same thing in neutral. but when its in every engaged gear my engine will bog down a lot and then idle at about 800, a little lopey but still living. any ideas?
Old Feb 16, 2011 | 05:17 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: transmission load is making my engine stall?
Stock camshaft? If the camshaft has too much duration, a stock converter can stall it out.
There's also a possibility of a bad converter or transmission.
Old Feb 16, 2011 | 05:25 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
i am currently swapping in a t5 so hopefully that solves my problem.
Old Feb 16, 2011 | 06:11 PM
IROC4U's Avatar
Car: 87 IROC
Engine: GM 350 soon to be supercharged
Transmission: tko 600
Axle/Gears: 3:73
try discconecting the lock up switch does it do it when its warm? or cold
Old Feb 16, 2011 | 06:27 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
it does it when its cold
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
