rear end swaps, what is the easiest to swap?
Old Feb 19, 2011 | 02:46 PM
stan36's Avatar
Assuming I could fabricate all the brackets and mounting for a torque arm, what would be the easiest fit for a third gen? Are the second gen 8.5s at all close to the same width to the third gen or would a mustang 8.8 be closer the the width neede for a third gen. Some detailed information is what I need.
Old Feb 19, 2011 | 04:16 PM
big gear head's Avatar
Re: rear end swaps, what is the easiest to swap?
The easiest would be a 9 inch Ford or 8 3/4 Chrysler because they have a steel housing that you can weld to. Any housing with a cast iron center is going to be harder because you can't easily weld to the cast iron. The 8.8 or 8.5 would require brackets coming off of the axle tubes or some kind of machined bracket that bolts to the back of the housing where the cover bolts on.
Old Feb 19, 2011 | 04:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
4th gen swap easiest - no fabricating - but it's still a 10 bolt, not any stronger than a 3rd gen rear. But as with a 3rd gen rear, can be beefed up to handle alot, just not no 600hp drag strip monster.
What's the goal? To handle what?
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
