7 inch 4.11 gears auburn Questions
Old Mar 1, 2011 | 09:16 PM
Joe's Rs's Avatar
Car: 92 Camaro RS
Hello everybody iv looked around but couldnt find much on this rearend. I have a 92 rs and I want to swap in a better rearend. Its not a daily driver so I dont really care about mpg.
Someone is selling a 7inch auburn 4.11 gears from a 87 pontiac formula. I am guessing this is a 26 spline so I know i will have to switch mine from 28 to 26. He is asking $250
Is this a good deal and will it work in my car??
-Joe
Old Mar 1, 2011 | 09:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 7 inch 4.11 gears auburn Questions
keep looking, dont swap back to a 26 spline rear, thats a step backward.
Old Mar 1, 2011 | 09:27 PM
Joe's Rs's Avatar
Car: 92 Camaro RS
even though the gear ratio is much higher?
Old Mar 2, 2011 | 06:07 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Like previously stated its a down grade. Dosent matter if the gears are higher the axles will be weaker. If your gonna have to buy new axles stick with 28 spline.
Old Mar 2, 2011 | 11:14 AM
big gear head's Avatar
I wouldn't buy a use Auburn for $1. You can't tell if it's worn out or not, and they do wear out. When they wear out they are scrap metal. They can not be rebuilt. Get a 28 spline Eaton Posi or a Duragrip and a new set of gears. You will be much better off. Used gears are hard to set up because the contact pattern is hard to read.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
