4th gen axle squeal around corners?
Old Mar 4, 2011 | 04:09 PM
555's Avatar
555
Car: 90 Z28, 74 Scout II
Engine: healthy 355
Transmission: t-5
Axle/Gears: 4th gen 10 bolt 3.23
Just finished my 4th gen axle install, everything is great aside from the parking brake???? and: now when i go around corners I get a almost metal on metal sound.... when I turn left: its on the left side, right:the right side.??? Going strait or a wide turn, nothing. Its a 10 bolt with a posi unit and disc brakes off a 96 Z/28.
Old Mar 4, 2011 | 04:23 PM
torque_is_good's Avatar
Re: 4th gen axle squeal around corners?
My 4th gen does the same thing. There are a couple of things you can do
grind or file off a bit of the caliper mount (you'll see where)
get some ceramic pads
I went with the ceramic pads and it's doesn't do it as much
It's not a seal or bearing so no worries.
Old Mar 4, 2011 | 06:53 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
right on! thanks bro, project for tommorrow!
Old Mar 4, 2011 | 10:39 PM
555's Avatar
555
Engine: healthy 355
Transmission: t-5
Could you point me in the right direction? I was hoping to see a groove or scratch on my rim from the caliper, but not so much....
Old Mar 4, 2011 | 11:11 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
you running 15s on the 96 brakes? I got a 2000 axle with 16s/18s and neither had issues except the 16s r 3rd gen offset and I had to pump up my air shocks to avoid scratching tires on wheel wells.
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
