Anyone know of a good place to buy a rear
Old Mar 8, 2011 | 09:40 AM
rich5's Avatar
Car: 91 camaro RS
i need a new rear for my 91 rs, i mine as well get a 10 or 12 bolt rear disk, you no somthing strong and that can take the power. i have about 1500 to spend ,so any suggestions. thanks rich
Old Mar 8, 2011 | 11:21 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Anyone know of a good place to buy a rear
Brand new 1500 won't really cut it, at least for a 12 bolt. but you can find a used one and still have left over. What kind of power are you trying to handle here?
Old Mar 8, 2011 | 11:51 AM
Robertg910's Avatar
Car: 1986 Z28
Engine: 355 crate motor
Transmission: Turbo 350, with B&M Mega shifter
Axle/Gears: stock axles and 273 gears..... grrr
Im in the same predicament..... I need a new or used rearend for my 86 Z28
Old Mar 8, 2011 | 11:55 AM
Robertg910's Avatar
Car: 1986 Z28
Am trying to find a direct bolt on solution, without spending a ton of money.
Old Mar 8, 2011 | 12:37 PM
rich5's Avatar
Car: 91 camaro RS
well id say 425 max at the moment, but a couple years down the road it might be a but more
Old Mar 8, 2011 | 12:40 PM
Robertg910's Avatar
Car: 1986 Z28
whats up Rich.... im looking for a direct bolt in rearend.. what about you?
Old Mar 8, 2011 | 01:03 PM
rich5's Avatar
Car: 91 camaro RS
well id like it to bolt right in but it dosent matter to much, as long as it has the same wheel base length ill be happy. my peg leg isnt goint to hold up to the Hp
Old Mar 8, 2011 | 01:04 PM
Robertg910's Avatar
Car: 1986 Z28
i heard that im pushing out 404hp and my stock 273 SUX
Old Mar 8, 2011 | 04:53 PM
IAGTA's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 w/SLP cold air intake
Axle/Gears: 9 Bolt 3.27 with PBR brake upgrade
From what I've seen for a new strong rear end the least cost option is the Ford 9" style unit ($2000 from a local shop called Quick Performance in Ames, IA). My investigation of 12 bolts indicates they are in the $2,300-2,500 range at a minimum. Add $300 for shipping. My understanding is that an upgraded 7.5" 10 bolt can handle a fair amount of power behind an automatic (350 rwhp?) from what I've read in various publications and on this web site over the years. The LS powered 4th Gen's have run with these rear ends with substantial more power than the L98's ever had. I would consider rebuilding your stock 10 bolt for $1,000.00 or so.
I'm sticking with my factory 7.75" BW 9 bolt but it is kinda expensive to rebuild and the ring and pinion options (new) are limited to one ratio.
Good Luck.
Old Mar 8, 2011 | 05:43 PM
Keoman's Avatar
Swapping in a 4th gen rear end will be a direct bolt in with some brake line modifications. However, it wont be any stronger than a 9 Bolt.
This is taken from the FAQ about rearends.
"What 10-Bolt Will Swap into My Car?
Any third- or fourthgen. While a fourthgen rear is a direct bolt-in, it'll be 2" wider or a bit less per side (note the link below for more info about width). Also, take note that if the gear ratio is changed in a swap, for example 3.08's to 3.42's, the speedo won't read correctly unless the transmission's drive and/or driven gears are changed. If you have a T-5, note the following link for gears and a how-to: https://www.thirdgen.org/forums/tr...ve-driven.html (T-5 Drive/Driven Gear Info--Please Contribute)
The following link provides more info about the fourthgen rear/swap: https://www.thirdgen.org/forums/fa...-gen-rear.html (Thinking 4th gen rear? Swap info inside)
Is a Fourthgen Rear End Stronger?
No stronger than a thirdgen rear with 28-spline axles."
If you are looking for bolt in and also strength upgrades, your going to be spending money. If you are looking to custom fab, the sky is the limit on rear ends.
My suggestion: Call as many junk yards (i like to call them RIP yards) as you can and find out who has 3rd and 4th gen camaros / firebirds / TA's and find yourself a read end. Dont just grab the first one you come across, take the cover off and find out first what it is and second if its worth buying (IE if the cones are shot, if there is actual gear damage, ect...) It will be your cheapest option. For strength upgrades, your going to have to spend more money, end of story.
Hope this helps.
LilHot
South Central
Apr 13, 2026 11:46 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
