Rear End Swap
Old Mar 9, 2011 | 08:19 AM
FreeBird86's Avatar
Car: 1986 Pontiac Firebird
Engine: 2.8L V6
Transmission: 5-speed
Axle/Gears: stock
Rear End Swap
I've been looking into purchasing another rear end for my 86 firebird, now i can go back with stock.....but would rather upgrade to a newer model such as a 99 because of disc brakes. I already have the rims from a 99 on there with wheel spacers, but was wondering if the rear end from a 99 would work width wise. if anyone has done something like this, some insite would be helpful......old rear end got loose on an ice turn and bent the axle upon curb impact...
or any suggestions???
Old Mar 9, 2011 | 08:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rear End Swap
Welcome to TGO, FreeBird,
As you can imagine there's not much on site that hasn't been asked and answered many times, so a search is generally a good idea. Check the following link for the info you require:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 9, 2011 | 11:11 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: Rear End Swap
I just did this swap, and trust me, i'm a novice. There were a FEW minor snags, but it was pretty much a direct fit. Your biggest issue will be Ebrake cables. I also had an issue with the center hose, but on your 1986 Firebird, you will probably be alright on that.
Old Mar 10, 2011 | 07:20 AM
FreeBird86's Avatar
Engine: 2.8L V6
Axle/Gears: stock
Re: Rear End Swap
Thanks for the reply...As soon as I get started (probably in the next couple of weeks due to finishing my c10 motor) im sure there will be plenty more questions....cant wait to get the bird back on the road.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
