CANT TELL IF MY B/W 2.77 IS POSI ....
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
IM 80% SURE THIS REAR END IS POSI-TRACTION. KAN ANYONE LOOK AT THIS AND GIVE A YES OR NO. SEE ATTACHED PICS. THERE ARE NO SPRINGS VISIBLE THRU THE 180 DEGREE OFFSET WINDOWS IN THE DIFFERENTIAL HUB . ALL I SEE ARE SMALL BEVEL GEARS. ITS A BORG WARNER 2.77 9 BOLT P/N 10040660 SER NO 11742
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: CANT TELL IF MY B/W 2.77 IS POSI ....
do the axles turn the same direction? if they do its posi.
YES THEY DO WHEN YOU SPIN THE PINION. THANX.
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
"posi" indeed.
Just FYI, its not all that good to have your vin number in your signature, IMO..
LSD/posi= are the same.
ANYBODY CAN GET IT OFF YOUR WINDSHIELD DATA PLATE. THE DMV HAS IT. I FIGURED NO HARM. WHAT POSSIBLE NEGATIVES DO U SEE FROM IT....I CANT THINK STRAIGHT I BEEN UP ALL NITE TRYING TO FINISH MY REAR END .
KO1
16
Oct 15, 2015 05:00 PM
