Need some bolt sizes for my 10bolt rear disc brake rearend
Old Mar 17, 2011 | 08:49 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I picked up a 3.23:1 rear disc brake rear out of a 1991 GTA for $125 last night. This will be going in my 1991 Z28 to replace the 2.73:1 drum rear it has now.
For whatever reason, someone removed the backing plate from one side and lost the bolts. Does anyone know what size/thread the backing plate bolts are for a 1991 10bolt disc rearend?
How about the caliper bolts? I'm missing those as well.
Heck, if anyone has either of those to sell and can ship today, I'm all ears.
Old Mar 17, 2011 | 09:16 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Need some bolt sizes for my 10bolt rear disc brake rearend
The following pdf files should provide the info you need.
JamesC
File Type: pdf
File Type: pdf
Old Mar 17, 2011 | 09:17 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
JamesC
Thanks - Do you have the .gif file that comes with the PDF? It doesn't seem to enlarge w/o them.
[edit] Just took another look at the rear and the damn caliper bracket on the pass side is missing!!
Old Mar 17, 2011 | 09:35 AM
JamesC's Avatar
You can zoom in if that will help. If not, let me know and I'll provide the info.
JamesC
Old Mar 17, 2011 | 09:40 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
JamesC
It won't zoom in w/o the associated GIF file - The PDF ties to it.
Old Mar 17, 2011 | 09:42 AM
JamesC's Avatar
Odd, zooms for me. Look at the tool bar when the pdf comes up.
JamesC
Old Mar 17, 2011 | 11:02 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
JamesC
You must have the .GIF file on your computer - The PDF refers to this file and that's the error message that I'm getting.
The PBR Caliper-2.pdf file refers to "4-91.gif" to zoom in on the PDF. If you search on your computer for that file, I'm sure you'll see it - Apparently its not "built in" to the PDF.
[edit] I wound up finding the GIF file on austinthirdgen.org - Thanks for the info! That's exactly what I needed.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
