Glorified Monza drivetrain?
Old Mar 19, 2011 | 10:43 AM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Any Chevy gurus out there know why GM used such a difficult-to-upgrade non traditional rear end design with the weakly T5 transmission?(besides cost!)
The drivetrain layout seems too close to a Saginaw 4 speed spindly rear end Monza I had in the 80's.
If I want to put a street carb'd 400 and keep the manual trans, it's T56 time with a $2500 9" or 12 bolt eh? Jeez.
Thanks for any old trivia on the above.
'88 IROC-Z28 T5 LO3 Vert w/imminent 400sbc swap (with missing straight across 3rd starter bolt hole drilled for 153t 400 bal flywheel)
Old Mar 23, 2011 | 10:14 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
Re: Glorified Monza drivetrain?
because,they already had the design(monza)AND because it was......CHEAPER to build
Old Mar 23, 2011 | 10:45 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the TQ arm set up is not expensive to upgrade, and it flat out WORKS. but yes the 10 bolt rear end is weak....
Old Mar 25, 2011 | 09:11 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
s60 is yet another choice
Old Mar 26, 2011 | 09:53 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Torque arm rear suspension is very versatile. You've got people drag racing and autocrossing with the exact same suspension, not even only teh same design but the same car without changes and having a blast at it.
It would be nice if we had a IRS with the pumpkin on a transverse leaf spring setup like the Corvettes, but that's too expensive for a pony car.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
usafirebird
Oct 1, 2015 01:57 PM
Chevykid810
Sep 28, 2015 12:57 PM
usafirebird
Exterior Parts for Sale
Sep 21, 2015 01:23 PM
2slowfox
Sep 18, 2015 01:49 PM
