Speedometer Cable Broken
i have an 83 camaro z28 i went to change my speedometer out since it was no longer working. after pulling the whole dash apart i finally reached it pulled the old one and placed a new speeo in its spot only to find it still was not working. i pulled everything off again and found the little red shaft inside the jacket of the speedo cable was in two pieces. any sugestions on what to do next? i was thinking change the cable out but please let me know. thanks
Car: `86 SS / `87 SS
Re: Speedometer Cable Broken
Make sure your speedometer odometer gears turn easily and for dozens of spins of the input shaft in the back of it.
(I've had a trip odometer get stuck. The speedo was otherwise fine and tried to work, but the trip odo. kept things from working properly.)
Z28/ZR1
Oct 23, 2015 01:04 PM
