what stall converter for my 700R4?
Car: 1992 trans am
thinking about rebuilding my 700R4 transmission in my 92 TA. its not a race car i just drive it on the streets. going with a corvette servo and maybe a stage 1 shift kit. i would like to have alittle bigger converter then the stock 1650 stall. the engine is all stock with the stock cam. what is a good stall to run in my set up? thanks!
Car: 1992 trans am
Re: what stall converter for my 700R4?
talked to a transmission shop today and they told me the most stall i can run with a stock cam is a 2000 stall in a 700r4. im just wondering how much better that will be over the stock 1650 stall?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
1) your stock stall is closer to 1200, not 1650.
2) Not sure why you couldn't run up to a 2400 stall, but I'm no expert here either.
3) Look into a S-10 pickup stall converter. I have one behind my 350, been in there 4 years now with no issues at all, works great!
It's cheap (or was) - I got mine from GMPartsdirect.com for under $150 shipped!
Although it'sc a V6 truck the converter stalls at about 2200 behind my 350 (might stall a little lower behind a 305 which puts you right at the 2000).
It has lockup, so works fine.
Do a
here for "S-10 converter" or something to track down exactly what converter (part number) to look for, then check GMPartsdirect.com to see if they still carry and the cost. About 4 years ago everyone talked about doing this, and so I thought I'd try it. No one mentions anymore now, but it really is a great swap and much cheaper (or used to be anyway) than a B&M or other brand of "advertised" product.
Do a
here for "S-10 converter" or something to track down exactly what converter (part number) to look for, then check GMPartsdirect.com to see if they still carry and the cost. About 4 years ago everyone talked about doing this, and so I thought I'd try it. No one mentions anymore now, but it really is a great swap and much cheaper (or used to be anyway) than a B&M or other brand of "advertised" product. Member
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
i did the same thing you did last year...i bought a 2400 B&M holeshot covertor, corvette servo, transgo shift kit...however...it did this to a old unit...lets just say it didn't hold up...slipping. but the covertor was good
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
