Rear end gearing and type?
Car: 1989 Pontiac Trans Am
Engine: 5.0 TPI LB9
Axle/Gears: 10-bolt 2.73
So i have an 89' trans am
wondering how i could find out the gear ratio, and whether its positrac or not!?
i dont know much of anything about the drivetrain so pardon my ignorance!
Re: Rear end gearing and type?
you can look under the center console lid for a GU# then check it on this web site
http://www.vibratesoftware.com/html_...ve_axles.htm#G
Engine: 5.0 TPI LB9
if your referring to the RPO codes those are non existent for my car, long gone lmao
im going to assume its the stock rear end, but its been through a few owners so i dont really know
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the car is 22 years old, no way to know what has possibly made its way intot he car by now.
im sure the axle hasn't had a fluid change in years, if ever, so now is the perfect time to pull the cover off and do that. while your in there, you can count teeth and see what the ratio is, and look see if its a open rear of a limited slip.
take a pic if you cant tell.
count the coverbolts too, see what rear you have, a 10 bolt or a 9 bolt
if its all original, its supposed to be a 2:73, and should be a limited slip 10 bolt
Engine: 5.0 TPI LB9
and im assuming the 3.08 would be the better?
is there any way to visually check or not really?
Engine: 5.0 TPI LB9
the car is 22 years old, no way to know what has possible made its way intot he car by now.
ill have to do that tomorrow when it gets lighter out! lol
as for doing the fluid change, never done one of those so i guess im gonna have to learn how haha
ty guys!
Car: 86 Trans Am
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
