odd shifting
Old Apr 9, 2011 | 07:24 PM
baboony's Avatar
Car: 1987 sport C and C
Engine: 2.8L
Transmission: 700r4w/ B and M kit
Axle/Gears: stock
odd shifting
It seems that driving between about 30-35 mph my trans is indecisive about what gear to be in. I see the rpms rise a few hundred then stumble back down. Trans fluid and filter were replaced a couple months back.Any ideas?
Old Apr 9, 2011 | 08:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: odd shifting
Normal. 2 things occur ...
1) as you stated, trans can't determine a good gear - wants to "hunt" between 3 & 4.
2) the torque converter lockup will also lock/unlock at speeds this low - it can lock in 3 or 4, and at speeds as low as 30mph
One way to get past this - switch to D instead of OD in these rare instances. Different grades will react differently, etc. So, just switch to D for awhile, then can switch back to OD when grade increases/decreases, or road changes, or speed limit changes.
If you are driving the car "properly" - the only place this should occur is in a 25mph zone. Since you should be driving 10mph over the speed limit (it's a Camaro!!!), it should only happen in a 25mph zone - get into a 35+ zone where the Camaro will be happy!
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
