Ford 9 inch help
Old Apr 18, 2011 | 04:27 PM
camarosobbing's Avatar
Car: 86 camaro z-28 t-tops
Engine: 387
Transmission: turbo 350 reverse v body 8 inch tsi
Axle/Gears: ford 9 inch 4.30 gear
Ford 9 inch help
Ok im getting ready to order a 9 inch for my car,But i keep getting mixed answers. I called moser they say you cannot reuse your stock factory disc brakes. I have seen where people say you can use the stock brakes. i am i missing somthing? Also i looked at the quick performance rear why does the torque arm mount look so much diffrent them moser? I have about 2500.00 to get this done. Just trying to find the best way to do this and not go broke.
Old Apr 18, 2011 | 04:38 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Ford 9 inch help
Yeah, Moser told me the same thing...but I had drums anyway and was considering converting to stock discs on the rear. Not sure, but it might have something to do with the way the stockers mount up and the big Ford style bearing ends....someone else may know exactly why.
They offer a Explorer disc kit that bolts up, or a drum kit (Torino I think). I didn't need disc that bad, so I opted for the drums. Probably the only real diff. between thier Ford kit and a stock Ford kit is that they drill the drums/rotors to fit the Chevy bolt pattern...
If you're dead set on disc brakes, maybe the stockers will work on a 12 bolt rear?
Old Apr 18, 2011 | 04:46 PM
Engine: 387
I not really set on disc i just thought since i already have the stock disc brakes on my current rear maybe i could save a few bucks. I think for the cheap set it was 350.00 extra. I dont do much street driving so im not really worried about a big high dollar brake setup
Old Apr 18, 2011 | 06:35 PM
The end of the rear end housing is MUCH too large for the brake setups on our cars.
You can pick up Expoder brakes at the junkyard by the crate full right now, that being the single most popular Cash For Clunkers turn-in. Go that route. They'll probably pay you to take em, instead of charging you for em. Just don't tell em why you want em; instead, look around in parking lots anf stuff, and find the year/model of Exploder that you want brakes off of, and tell em you're looking to fix your [insert year & model here] and need all the brake part because the Firestone tire blew up, or the ball joints broke, and trashed it all.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
