changing shift points
Old Apr 26, 2011 | 04:25 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Is it possible to re-govern a 700r4 to shift earlier without ruining the transmission? My reason for asking is because my engine makes peak power at 4000rpm but my trans shifts a little over 5000rpm at WOT.
Old Apr 26, 2011 | 07:49 PM
Re: changing shift points
Yes. Thats' how you "adjust" a 700, the proper way, in fact. Set the TV cable where it BELONGS, then work on the governor to tune the shift points. You can buy spring & weight kits for them to set it up how you want it.
Old Apr 26, 2011 | 07:50 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Sure. You'll want a governor weight recalibration kit.
Dana should be able to guide you on it and hopefully find the parts you need. He's very friendly and knowledgeable when it comes to 700-R4s.
Pro-Built Automatics
934 5th Street , Calimesa CA 92320
Attn: Dana - 909-795-1876
Old Apr 27, 2011 | 03:23 PM
lb9 GTA's Avatar
Thanks guys. I'll check that out.
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
gwade12
Aug 8, 2015 08:17 AM
