Transmission wont shift into 2nd
Old May 5, 2011 | 11:04 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
So last night i decided to take my car out only to my surprise i was unable to go to 2nd gear. (auto tranny 700r4)
I added a quart of fluid, and that didnt help, although it was a bit low.
Am i pretty much screwed? or can it be something simple?
Can it be the governor gear? how can i diagnose it?
*UPDATE*
took out governor gear and it was in perfect shape, thing looked brand new.
All help appreciated.
Old May 6, 2011 | 10:55 AM
Car: 1986 Iroc-Z
Engine: 355
Re: Transmission wont shift into 2nd
anyone?
I have another 700r4 that i could use for parts, would swaping the valve body help at all? or is this not a valve body issue?
Old May 6, 2011 | 12:14 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Check that the tv cable is adjusted right and that its not leaking fluid.
Old May 6, 2011 | 12:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'm not too sure on the internal workings of the 700R4 but it should be reasonably similar to TH350/400.
Will it shift into third? If so then there's a possibility of a failed intermediate sprag. You always pull the pan to see if there's any hard parts in it. Would be a good time to change the filter while the pan is off.
Old Jul 7, 2011 | 08:19 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
i have almost the same problem, it shifts fine sometimes but once and a while it wont shift into 2nd without me letting off the gas...i checked the fluid and its fine, but i dont know what to do. I really dont know crap about trannys so I am clueless.
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
