Hard Shifts Cold; Smooth Shifts Warm
Old May 8, 2011 | 07:46 PM
RJ_Moore's Avatar
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
Hi, I have a 305 700R AT which shifted hard between 1st and 2nd when it is cold, however when it warms up, the hard shift between 1st and 2nd becomes smoother to smooth.
Throttle Body Cable was adjusted by mechanic, and got worse, now it shifts real hard. Throttle Body Cable is said to be okay. Provided copy of throttle body cable adjustment procedure to mechanic to make sure he understood it, and it was adjusted again. Still a real hard shift from 1st to 2nd.
Does anybody know what's going on with my AT from those symptons?
Richard.
Old May 8, 2011 | 10:11 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Hard Shifts Cold; Smooth Shifts Warm
Why dont you to take it to a transmission technician instead of a mechanic. That what I would do. its possible a valve is too tight when it is cold and as it warms up it gets loooser which equals the hard then softer. I dont know how likely that is. I would take it to a KNOWN GOOD trans. tech and see what they say.
Old May 9, 2011 | 12:14 AM
RJ_Moore's Avatar
Axle/Gears: 7.625
Thanks for the advice. The mechanic is at a Transmission service center, but I don't have confidence the mechanic is that good. I'll talk with the service center owner and see what's up.
What valve are you referring to? Richard.
Old May 9, 2011 | 08:43 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
The TV valve?
Old May 12, 2011 | 05:52 PM
GutSmack's Avatar
Car: 1991 Camaro RS
Engine: V8 305 TBI
Transmission: Auto..
Did you ever find out what it was? Mine is doing the exact same thing.. and it's the same tranny with a 305 TBI. Don't quite understand it and I am on a tight budget.
Old May 12, 2011 | 06:09 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
That is the same as mine, a 305 TBI, and it shifts smoother when I accelerate more aggresively, but I have not had time to go to the transmission shop.
Keep posted. Richard
Old May 14, 2011 | 01:33 PM
scaggsj's Avatar
Car: 1991 Camaro RS
Engine: 3.1L
Axle/Gears: Stock
Mine does this as well although I have the 3.1 700r4. Once its warm it shifts great. I put some Lucas in it and it worked good for about two days then went back to the same. I havent had a chance to take it to trans shop yet. Got a lot of other small things Im working on. Keep us informed to what you find.
Old May 14, 2011 | 03:01 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
Will do, and there is no doubt warmer weather the AT works much better, even normal.
TV valve may be the problem as the tranny shop adjusted and checked out the TV cable.
Richard.
Old May 15, 2011 | 01:22 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
so they checked yours out and adjusted it and it is doing better?
Old May 15, 2011 | 12:39 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
only when it is warm, and not always, I think it has to do with the TV cable and valve setup, since a slow acceleration hardshifts cold. I haven't had it sorted out yet, just working through it.
Old May 15, 2011 | 08:10 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
How hard is hard? Is it firm, or a "bam"? My 86 is firmer when cold, but softens up a bit when warm, and it's normal.
Old May 15, 2011 | 11:16 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
Normal? Whatever happened to the GM smooth AT shifting? This hardshifts so hard, what I thought, at first, was tire chirps, now, I believe are transmission chirps!
It's hard for me to tell, because I am deaf in my right ear, and unable to tell direction of sound sources.
What makes you think that hard shift is normal? Slow acceleration, hard shift, aggressive acceleration, hard to call it a hard shift.
Yes warmer does work a lot better than cold, but really? the 700R is supposed to shift hard when it is cold?
Old May 16, 2011 | 01:04 AM
That's too hard for a stocker, even with the tv cable pulled tight. I'd take it to a tranny shop at this point. Could be a valve in the transmission.
Old May 16, 2011 | 10:39 AM
RJ_Moore's Avatar
Axle/Gears: 7.625
What do you mean by pulled tight? What transmission valve?
I am no mechanic.
Richard
Old May 16, 2011 | 10:54 AM
I am no mechanic.
Richard
There is an adjustment for the TV (throttle valve) cable. The tighter the cable the higher the trans pressure will be, hence the harder the shift will be.
Google how to adjust the cable. It is really easy. You should be able to shift into 1st from 2nd automatically when you punch it to the floor. If this doesn't happen, you need to put more tension on it by pulling it back a bit.
Old May 16, 2011 | 11:16 AM
RJ_Moore's Avatar
Axle/Gears: 7.625
So, loosen the TV cable?
Old May 16, 2011 | 11:42 AM
You need to google this. I would start by going in a notch. The cable can be adjusted by pulling it in or out. There is a detent you push with a screw driver. That allows you to adjust in or out. I'm just not explaining this as good as the directions say. It is quite easy. In would allow it to shift sooner, and the shifts will soften up.
Old May 16, 2011 | 11:52 AM
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Try this.
Old May 16, 2011 | 11:53 AM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
its fine my car does that but i have a corvette servo and it barks the tires in 1-2 all the time and its sweet b/c it does it in 2-3 to
Old May 16, 2011 | 12:06 PM
Here's an other one.
http://www.73-87.com/7387garage/drivetrain/tvcable.htm
Your tv cable could be the issue, or you may have some other troubles.
Old May 16, 2011 | 11:46 PM
RJ_Moore's Avatar
Axle/Gears: 7.625
Thee TV cable check out fine, but it was adjusted too tight, so we backed it off a bit, and the ride home was pretty good. Tomorrow morning on my trip to the liquor store, I will see what it is like when it is cold, although the car sat for a couple of hours before the TV adjustment was backed off. Will confirm my findings tomorrow.
I followed the two links, printed out the 700R4 adjustment info, and gave it to the transmission service owner. Did not seem to know how to adjust the 700R4 for a smooth shifting drive.
Old May 17, 2011 | 01:53 AM
To some the r4 is before there time. Please let me know how you make out.
Cornholio7979
Sep 20, 2018 02:31 AM
diana227vegas
Jul 8, 2016 12:27 AM
Matt86IROC
Sep 7, 2015 06:30 PM
someone972
Aug 30, 2015 12:52 AM
