What a gyp-axleshaft disappointment
Old May 14, 2011 | 09:28 PM
dixiebandit69's Avatar
Car: '89 Firebird Formula
Engine: TBI 305
Axle/Gears: 10-bolt, 3.42s, Torsen diff.
I am ready to upgrade my '89 Firebird's rear-end to a used Torsen unit out of a 4th gen, but I knew I had to upgrade to 28 spline axle shafts.
No problem, I have a wrecked '92 Camaro RS (305, T5) for parts. So I take them out and count the splines, AND THEY ONLY HAD 26 SPLINES. WHAT THE HELL?!
The point of this post is that the factory doesn't always do what they say they will, so don't assume that a '90-up rearend has 28 spline axles. You gotta count them.
Old May 15, 2011 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What a gyp-axleshaft disappointment
I've been around thirdgen's a long time, but I've never encountered/heard of the issue you describe (GM's wild and crazy though so who knows?) Would it be more likely that the 26-spline axles, etc. were swapped in at an early point for some unknown reason?
JamesC
Old May 15, 2011 | 07:42 AM
Yup.
Mass production being what it is though, the odds of that car HAVING COME WITH those obsolete parts, are somewhere between Slim and None, and Slim is now sitting in None's lap on the bench. More likely, somebody just swapped out the whole rear at some point in the car's life.
In case anybody ever wonders why I tell people to IGNORE THE "CODES" and instead LOOK AT THE PARTS, or thinks I'm some kind of a jerk for telling them that the "codes" ARE NOT RELIABLE, this is exactly why. Stuff is just way too easy to swap around.
Go here. http://www.summitracing.com/parts/SAG-EV10-4/
Old Dec 30, 2011 | 06:44 PM
Engine: TBI 305
I don't mean to bring up an old thread, but I just got back from a salvage yard and found ANOTHER '92 Camaro RS with 26 spline axle shafts.
This makes three '92 Camaros with 26 spline axles so far (I found another one a few months back but didn't say anything).
I guess they could have been swapped at some time in the past, but three of them, all the same year? I think it's looking more likely that GM was trying to get rid of all their third-gen inventory in anticipation of the wider 4th gen axles, so they just started throwing some left-over 26 spline alxes on the assembly line.
Old Dec 30, 2011 | 06:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you would think and left over 26 spline stuff should have been used up long before 92, but who knows.
Old Dec 31, 2011 | 01:16 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
One would be rare. Finding 3 like that really makes you start to wonder.
