Tapping noise from torque converter/flywheel area
Old Dec 29, 2011 | 04:24 PM
JamakaDoodle's Avatar
Hello, I've owned my Camaro(91 RS 305 TBI) for just over a month now, and I've noticed a tapping that is loud out of gear (P/N) and quiets but doesn't quit in gear (R/OD/D/2/1).
It is really prominent when coming down from around 2500RPM to idle.
My father in law and I have looked under the inspection plate made sure all bolts are tight on TC and flywheel.
We also inspected for cracks on Flywheel but didn't notice anything.
I took it to one of our local guys who suggested it could be the starter pinion not returning all the way, which is the least labor and time intensive part to replace. I just wanted to know if anyone else has had a similar problem, or can vouch for this?
Outline for easier look over:
  • Tapping from Torque Converter/Flywheel area
  • Bolts are tight on TC/Flywheel
  • No cracks noticed on Flywheel
  • Louder out of gear that in gear
Thanks in advance!
Jam
Old Dec 29, 2011 | 05:49 PM
Re: Tapping noise from torque converter/flywheel area
Cracks inthe flex plate will be right near the center, usually right around the bolt holes, and VERY hard to see with the whole thing assembled.
That sounds like the most likely cause.
See my signature for a helpful mental discipline.
Old Dec 31, 2011 | 12:43 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
when you do replace it. always upgrade to a sfi rated flex plate.
Old Dec 31, 2011 | 01:42 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
gta892000
Aug 11, 2019 11:16 AM
gta892000
Sep 16, 2015 12:37 AM
Ragtop Man
Sep 12, 2015 12:23 AM
Randomtask2
Sep 7, 2015 05:06 PM
dimented24x7
Sep 6, 2015 03:51 PM
