Coan vrs pi converters
Old Dec 25, 2011 | 03:33 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi all
I currently run a 3200 10 inch coan converter with 3.23 gear
Would swapping to a vig 9.5 2800 be worth it??
I'm looking for more street perf car is modded with
Well over 400 hp
Thx gta
Old Dec 25, 2011 | 06:11 PM
robvano's Avatar
Car: 72 Chevelle
Engine: 468
Transmission: Muncie
Axle/Gears: 355
Re: Coan vrs pi converters
It depends on the cam and how your tranny is set up.
I ran that same converter, it put out great performance, but it became tiresome for me on street. I've replaced it with a TCI 2800 and I like it a lot better.
If you know what cam you’re running you can get the manufactures recommended stall from their website.
Old Dec 25, 2011 | 08:12 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Yeah mild comp 268 I too like the wot but
Not the low speed feel in town
Old Dec 30, 2011 | 10:20 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Do a gear change 1st and see what happens.
A 3.73 would be a lot better.
Actually for the little amount of driving you do, you should get a 4.10 gear and some drag radials.
Old Dec 31, 2011 | 10:19 AM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
Hey bud,
long time no talk do you think 4.10 would be a bit much on the street?? I guess gears are a bit cheaper than a converter.....
Old Dec 31, 2011 | 11:24 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
All depends what you want.
With a 4.1 gear and you in 3rd gear at 6000rpm you would be going about 112mph
With a 3.73 gear and you in 3rd gear at 6000rpm you would be 124mph.
Since you never race your car and only do short trips, 4.10's would be the best if you had drag radials. Without DR's, you would shred the tires off.
A 3.73 gear would sacrifice a little mpg but give you more grunt on the bottom rpms.
You got a series 3 carrier in your diff right?
And you put on my diff girdle?
Personally, I dont think switching converters will give you what you want....
Old Dec 31, 2011 | 12:42 PM
GTA's Avatar
GTA
Car: 1992 GTA
Engine: running
Axle/Gears: both
I wonder if there would be a great perf diff between the 3.73 and 410 gears
Yes it is a 3 series carrier
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
