Rear Diff ID?
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Rear Diff ID?
I have a 91 Firebird that I am swapping over to a 3.73 posi. Is there a way to ID the axle splne count without popping off a axle and counting them? I know since its a 91 it should have a 28 spline rear axle but the car is 20 years old there is no saying over the years the rear blew up and someone threw a junk yard rear in there from a 87...
thanks
thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Diff ID?
You need to pull the axles and count the splines. Nothing visual can tell you if it's 26 or 28 splines.
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Re: Rear Diff ID?
thanks
thanks
http://sethirdgen.org/reardata.htm
Here's where you can look for the code. Depending how rusty the rearend is, you might have to wire brush it.
It's really just best to pull off the pan and look for the ratio stamped on the ring gear or pinion and inspect the differential to see what one it is. If the ring ratio matches the one stamped on the tubes, most likely its the same one.
Re: Rear Diff ID?
Insomnaic,
If you're going to swap gears, you'll have to yank the axles anyway, so....
JamesC
Re: Rear Diff ID?
Car: 87 IROC L98
Re: Rear Diff ID?
thanks
thanks
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Rear Diff ID?
Originally Posted by
[URL
[URL
http://sethirdgen.org/reardata.htm[/URL]
Re: Rear Diff ID?
Umm..there might be. You can try looking in the Hanes manual for 3rd gens.
Orr89RocZ
Oct 7, 2015 12:47 PM
