4th gen rear ends
Old Dec 23, 2011 | 06:04 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
4th gen rear ends
While at the JY today I came across a '94 & '96 z-28's. Both cars still had their complete disc brake rear ends and were stick shift cars. As I understand it these are the LS type and will bolt up to a '89. Is this true? And can anyone hazzard a guess as to what the gear ratio might be, as neither car had a tag or spid sticker remaining. Thanks for helping a newbie in these types of cars.
Old Dec 23, 2011 | 06:25 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4th gen rear ends
https://www.thirdgen.org/forums/tran...-10-bolts.html
Old Dec 23, 2011 | 06:56 PM
reride's Avatar
Engine: 5.7 TPI
Great info and thank you very much for the lead. It answered the fitment question. But since neither car still have the RPO's I was wondering what gear ratios might be more common to stick-shift cars. My real goal here is for the brake upgrade, but, info on the gears would be helpful to if possible.
Old Dec 23, 2011 | 07:04 PM
Car: GTA
Search will give you 99% of any questions you ever have. In this case, it was easy for me to find because I have posted it MANY times, so I could narrow the search down to just Posts by me to find it faster.
https://www.thirdgen.org/forums/post...573-post8.html
Not trying to come down on you at all. Just showing you that using the Search feature is usually the fastest way to get the answers you want.
Old Dec 23, 2011 | 07:27 PM
reride's Avatar
Engine: 5.7 TPI
BlackenBird, I don't feel slammed at all. I was trying to take an easy out, I recently had surgery for 2 broken hips and didn't have my grandson/helper with me to crawl under the beasts.
Old Dec 23, 2011 | 07:31 PM
Car: GTA
That sucks. Hope they heal well.
Short of doing that rotating check or opening the diff cover & counting teeth, so is no 100% sure fire way to know. Rear ends are an easy thing to swap so there is no telling, for sure, if a stock rear end is still under a 3rd gen.
Old Dec 23, 2011 | 07:45 PM
reride's Avatar
Engine: 5.7 TPI
Things are getting better, I just don't get up or down real fast and twisting is out of the question. Thank you again for your assistance.
Old Dec 23, 2011 | 07:52 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
if it's a manual i'm pretty sure all the z28s came with 3.42 gears. my fourth gen rearend is a 3.42 but i'm not sure what year it is from.
it bolts in fine except it is about 3.8 inches longer than a 3rd gen axle, so you'll need an adjustable panhard bar to center the gear housing.
you'll probably need help getting it though, the thing is HEAVY.
Old Dec 23, 2011 | 08:10 PM
reride's Avatar
Engine: 5.7 TPI
Thanks for the info ol' Paddy, me boy. The cars are a '94 & '96, my grandson and his Dad are my arms, legs, and back for next little while. My IROC will be my grandson's someday so he doesn't complain, but, my son-in-law is a different story.
Old Dec 26, 2011 | 05:17 PM
reride's Avatar
Engine: 5.7 TPI
My grandson & son-in-law went to the JY and got the R/E out of the '94 Z28 today, It has the rotors, PBR calipers, sway bar, and parking brake cables.
When turning the rotor one complete turn, the pinion spins approx. 3 1/4 turns (3:23's).
Did these R/E's come from the factory with backing plates or did someone remove them?
I tried to post a pic, will serch how to do that and post one.
Last edited by reride; Dec 26, 2011 at 06:34 PM. Reason: Question deleted-answered in FAQ
Old Dec 26, 2011 | 09:53 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
No, there is.
The sure fire way to tell the ratio on your rear end is looking for the stamping on the ring gear. It will tell you the number of pinion gear teeth to ring gear teeth. ALSO, there will be a stamping on the pinion as well.
BTW, I've only dealt with STOCK GM ring and pinions, so I don't know about aftermarket. I would assume they'd have the stampings as well, or its a crappy piece.
In this example, 11:41 >>> Thus 41/11 = 3.72727272 which is roughly 3.73s
Attached Thumbnails 4th gen rear ends-img00250-20111127-1634.jpg   4th gen rear ends-img00250-20111127-16340000.jpg
Old Jan 1, 2012 | 06:46 PM
reride's Avatar
Engine: 5.7 TPI
After taking a closer look at the '94 Z car RE I purchased I noticed it has an electrical connection on top of center section, does this mean it came with traction control or ABS?
We got all the brake lines from the chassis connection for rubber hose to the disc's. Will this hose thread into my third gen chassis connection? I found the answer to this previously but, couldn't find the second time I searched for it.
I, also understand that I will need the PV...correct or no?
And, lastly for this post is there anything from the front brakes that can be used on a third gen?, as they looked to be nearly new.
Happy New Years Everyone!!!, And Thanks.
Old Jan 1, 2012 | 07:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
[QUOTE=
Happy New Years Everyone!!!, And Thanks.[/QUOTE]
lti [1993-97]front brakes are not worth messing with.1998 up front brakes are the ones to use.
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
