Need carrier info
Old Jan 1, 2012 | 06:44 PM
RicerEater78's Avatar
Need carrier info
I've got an 89 fire bird formula with a 2.73 open rear. I'm looking to switch to a 3.42 posi but I can't find anybody parting out locally. so I'm going to just buy a carrier from somewhere else, but I need to know what to look for.
this car is my daily driver so I can't just take everything out and look. does anyone know offhand the info or where I can find it? I appreciate any help I can get!
Old Jan 1, 2012 | 07:42 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Need carrier info
Sounds as if your looking for something used but if you decide to go with new parts and if its just going to be a daily driver than you can start by switching your axles to 28 spline(if needed) and buy a 28 spline Eaton Posi. and 3.42 ring and pinion with a L.P.W. support cover. Its not a inexpensive way to go but that's what I did with my DD and am very happy with my decision.
Old Jan 1, 2012 | 07:44 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
did you read this?https://www.thirdgen.org/forums/tran...bolts.html.all the posis from the forth gens will work if your axles are 28 spline.
Old Jan 1, 2012 | 07:59 PM
Engine: TBI,5.0
Just for kicks here's my build. =
https://www.thirdgen.org/forums/tran...de-photos.html
Old Jan 1, 2012 | 08:41 PM
I am hoping for used but new and cheap would work. I'm only looking to put about 275 rwhp down. is there a specific size for the crown gear? I know certain carriers won't work in some housings which is mainly what I'm looking to find out
Old Jan 1, 2012 | 08:43 PM
your setup cost quite a bit. I'm really hoping to switch to a posi on a budget. btw, your car is gorgeous!
Old Jan 1, 2012 | 08:54 PM
Engine: TBI,5.0
Thanks, yes I went the "path less traveled" but had the opportunity to have one of, if not the best rear end shops in CA. work on my car .I let them/him walk me through the process and in return received a life long commitment from his shop.
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
