TH350
Old May 20, 2011 | 02:03 AM
downloadking007's Avatar
Car: 1992 Camaro RS 25th Aniv
Engine: Vortex 350 TBI
Transmission: 700 r4
TH350
putting a th350 (short tail end) in my 92 camaro, do I need a longer drive shaft or will the one i have hooked to my 700r4 work, anything will help thank you!
Old May 20, 2011 | 08:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TH350
You'll need a longer shaft.
Old May 21, 2011 | 12:45 AM
dano2377629's Avatar
Car: 1986 IROC Z Z28
Engine: 355
Transmission: TH 350 3200 rpm stall
Axle/Gears: 3.73 posi
Re: TH350
Yep need longer shaft. Its well worth it though, also need to relocate tourque arm or get b&m kit. If running strong motor it gets more expensive. Recommend Spohn tourque arm and move tourque arm to crossmember. They sell the whole kit for what your doing. The tourque arm mounting to trans wasnt one of gm smarter ideas. But original motor wasnt pumping close to 600 hp like I am either. Good luck.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
