drift proofing c clip axels
Old Jun 2, 2011 | 02:46 AM
McDeath's Avatar
Car: 92 RS
Transmission: WC T-5
Axle/Gears: 4th gen 3.42, mini spool
ok i did some searching i didnt come up with what i was looking for, so: right now i am running a welded diff, i will be swapping in a spool soon, and want to make sure im not going to have any surprises mid drift with a c clip gone rouge or something. durability and reliably are my priorities here. what can i do to drift proof my OE axels in a spool and factory 7.5 10 bolt. my 305 is stock for now, i am am looking to build a 300hp 350tq min 350 in a year or
thanks
Old Jun 2, 2011 | 07:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: drift proofing c clip axels
1. remove 10 bolt
2. trash it
3. buy moser 9" or 12bolt rear
4., and no issues with crappy c-clips.
seriously, im not being a smart ***. its the only way to remove that issue from a 10 bolt. Only available option are the c-clip eliminators, but they are for drag cars and not rated for lateral loading.
or pick up a 9 bolt, but parts are getting hard to find.
Old Jun 2, 2011 | 10:19 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Originally Posted by //<86TA>\\
1. remove 10 bolt
2. trash it
Old Jun 2, 2011 | 11:12 PM
McDeath's Avatar
Car: 92 RS
really? damn, that is not what i wanted to hear.
is losing a c clip a catastrophic failure, like destroying the whole rear end, or will a axel just go sliding out of the rear end into the middle of the track or what?
it a c clip failure a "if" it happens or a "when" it happens?
Old Jun 2, 2011 | 11:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Like a low budget off roader who doesn't care about taking stuff back apart.
A few tack welds will stop them from falling out on their own.
Old Jun 2, 2011 | 11:28 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Drifting with welded gears??!!??
How long have you done that? I've always heard dirt cars doing it, but
heard street cars eat 'em or toss an axel.
Old Jun 2, 2011 | 11:52 PM
McDeath's Avatar
Car: 92 RS
gumby, thats what i needed man. thanks. anyone have a good close up of the c clips and where i would need to tack them?
havoc, the majority of amateur drifters run welded diffs. yeah sometimes they grenade, but most of those guys can swap out the whole pumpkin very easily in cars like a 240sx. the most ware really just comes in parking lots and turning at full lock. but im also running a 50 - 60 tall tires so that helps.
Old Jun 3, 2011 | 12:50 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
open it up and use your own best judgement..........
Old Jun 3, 2011 | 12:59 AM
McDeath's Avatar
Car: 92 RS
yeah, im looking it up now. ill defiantly tack them in there when i put my spool in. what a horrible design...
Old Jun 3, 2011 | 11:26 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no real science to it, you can decie to do a quick zap that might let you cut them lose later, or burn em into one piece.
making sure the part is clean will help a quick zap, oil will wick up to heat.
Old Jun 3, 2011 | 12:11 PM
McDeath's Avatar
Car: 92 RS
sounds like a plan. now i just need to choose what spool to buy and get it installed...
Old Jun 3, 2011 | 01:17 PM
Car: '87 Camaro
Learned this old wives tale is not always true!! LOL
Show them good ol' 3rd gens can drift with the best!!
Good luck
Old Jul 8, 2011 | 01:50 AM
McDeath's Avatar
Car: 92 RS
ok, my housing and axel tubes are 6hk, them from an '88. but the guts appear to be original because they are 28 spline, and i know this rear has been opened up before because she it rocking timkin bearings. anyway, i broke the original welds. the guy got zero penetration.
the welds just popped off the spider gears and it went back to being an open.
i had it rewelded properly
and the c clips in the newer axels are recessed into the spider gears with the pin keeping them that way. no way they are coming out.
the rounds bit protruding from the spider gears contacting the pin are the ends of the axels. the c clips are recessed completely.
hopefully this will help someone else at somepoint
Old Jul 8, 2011 | 08:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Good deal
Old Jul 9, 2011 | 07:43 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
This thread has my curiosity up. How are C-Clip axles retained with a spool ?
Old Jul 9, 2011 | 09:33 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
C-clips can break during lateral loads?
Old Jul 9, 2011 | 09:36 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
loving the red neck posi/spool!!!!
Even tho the c clips are recesed they still can be a prob. The end of the axles can break off and or the clips can break and fall out.
You could also use disk brakes to help in your axle holding quest, not the safest but the caliper and rotor kinda help hold the axle in place incase of axle/flange failure during your championship chasing runs..
You could also buy a replacement axle for your aplication and it'll help a bit..
use a quality wheel stud also..
Old Jul 9, 2011 | 12:45 PM
problem2420's Avatar
Car: 86 ta
Engine: 305tpi
Transmission: t5
Axle/Gears: 2:77 soon to be 3:42
Good luck
agreed! haha thats what i plan on doing with my ta, but dang c clips really come off like that? guys around here do donuts 24/7 with thier 3rd and 4th gens and the most that happens with thier big ol goffy rims is they snap the axle becuase to much wheel hop.
Old Jul 9, 2011 | 11:33 PM
McDeath's Avatar
Car: 92 RS
its going to get a 4th gen disk rear sometime this year. and a hydro e brake : )
but i need practice more than anything else right now. im going down to myrtle beach to slide tomorrow.
RS Reaper
Oct 17, 2018 07:52 PM
Night rider327
Feb 25, 2016 09:50 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
ULTM8Z
Oct 2, 2015 01:25 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
