t56 swap questions
Car: 88 IROC-Z
Transmission: 700R4-currently being mildly built
Axle/Gears: stock 2.73:( with limited slip
t56 swap questions
ok, so my 88 IROC-z 305 has a 700r4 and I am getting it ready for a t56 swap and had some questions:
Does the brake booster have to come out for the master/slave cylinders to fit?
On the shifter bracket, there is a front section, right ,and middle that have spot welds. which spot welds have to be drilled out?
Do I need a new drive shaft?
There are cutouts in the insulation by the pedals, 1-1'' oval and 2 diagonal small holes. are those for a clutch pedal and cylinder, even though there are no holes for them in the firewall?
thanks for any help. If you have some tips on making it easier please let me know.
Re: t56 swap questions
https://www.thirdgen.org/forums/tran...ap-thread.html
1992 Trans Am
Aug 8, 2015 08:16 PM
