BW 3.27 rear end. axle seal help
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
anyone ever do an axle seal on these? these rear ends are different from others because there is no C clip. you gotta take out the 4 bolts at the end of the axle to remove it. also the seal is mated to the axle bearing. will i need to replace the bearing when i change the seal?
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: BW 3.27 rear end. axle seal help
Yeah different than the 10 bolt. It has a pressed on collar, the bearing and finally the seal. All three need to be pressed off to replace the seal. I would plan on replacing the bearings when you replace the seal. I've done a few, and the bearing always gets damaged. A large hydraulic press is needed, a machine shop probably can do it for a fair price.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
