clutch opinions
Old Jun 14, 2011 | 07:46 PM
nascar2496's Avatar
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
clutch opinions
My centerforce dual friction clutch is slowly dying. its slipping pretty bad under heavy acceleration So im thinking of just putting the same clutch in and a new flywheel as well. before i purchase anything i just wanted some opinions on the different brands/types of clutches and any recommendations on flywheels.
the car has a 305 tpi (for now) its an 86 block with the two-piece rear main seal. i have a t5 trans behind it. I am eventually putting a 350 out of an 88 formula in my car that will probably have about 400 hp. I know the t5 wont hold behind that so im not even going to bother, so i was thinking either a tko 600 or t56. is there a clutch setup that is interchangeable or am i just buying new parts over and over again?
Thanks!
Old Jun 16, 2011 | 07:38 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: clutch opinions
If you go t56 you will need a new clutch setup again. The t56 uses a different style clutch than the t5 so there is no way of getting around that.
If you go TKO however you can reuse your t5 clutch and hydraulics as it uses the stock T5 bellhousing.
Old Jun 18, 2011 | 04:31 PM
nascar2496's Avatar
Engine: 305 tpi
Re: clutch opinions
ok thanks for the info, anyone have any info on different clutches or are they all about the same? what about flywheels? im looking at the gmpp flywheel on summit for $180
Old Jun 18, 2011 | 05:24 PM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
Re: clutch opinions
im running a centerforce steel flywheel with a ram kevlar clutch love it with my 383 and tko 600
Old Jun 19, 2011 | 02:23 PM
subroc's Avatar
Engine: 355 TPI
Re: clutch opinions
Im researching that now myself actually as i had to pull my trans for a input shaft leak. There are several aftermarket clutches out there that people seem to be running. Since your car is going to be putting down some good power eventually you might want to think about a good aftermarket clutch. Centerforce DF clutches are good (though ive heard otherwise as well). Then there are the Spec clutches which seem to have good reviews too (though again ive heard otherwise). Basically what one person likes in a clutch another may hate so its all personal preference. Also there are people out there that say a certain clutch didnt last more than a few hundred miles and they will never buy another one...but its that person who probably didnt read the break in instructions and take it easy on the clutch for 500 or so miles before beating the ever living crap out of it. If you break in a clutch properly and everything else is adjusted correctly (ie. throwout bearing is not putting pressure on the clutch fingers) then you should be just fine.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
Jlanz55
Sep 29, 2015 08:55 AM
mfp189
Sep 27, 2015 09:25 AM
