help with trans linkage please! Need bolt size tech
I swapped a v8 and turbo 350 trans out of a mid 70's car into my 86 Berlinetta. The car it came out of had a rod type shift linkage and as such didn't use the holes/bolts to mount the a cable shift linkage. Got out the welder and made a bracket that works however I can't figure out the thread pitch/size of the bolts that hold the bracket onto the two holes on the side of the trans. Can anyone help out with the size of these?
Car: `86 SS / `87 SS
Re: help with trans linkage please! Need bolt size tech
M8x1.25 is what the 700-R4 7 200-4R use.
Thanks for the quick reply! I will grab a couple of those and give em a shot. Those transmissions seem similar enough I doubt they changed the threads
THey changed the threads.
Blee dat.
The T-350 came out LONG BEFORE metric ANYTHING hit American cars. You can pretty much take to the bank, they're NOT metric.
Expect that it has something more sensible.
IIRC the factory T-350 brackets wnet under a couple of the pan bolts, which if memory serves, are 5/16"-18.
Blee dat.
Won't be metric. You can be sure of that. Pretty sure they're 5/16"-18.
84z96L31vortec
Aug 20, 2017 12:16 AM
toronto formula
Nov 10, 2015 06:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
knight72
Aug 10, 2015 09:32 PM
