easy question. Fill all the fluid
Old Jun 29, 2011 | 03:12 PM
mikiman's Avatar
Hello,
I have rebuilt my 4L60 and I'm going to put the oil. It needs 7.9 liters of dexrom II, but I'm not sure if I must follow an expecific procedure, because now the converter, pump, etc are empty.
Must I put all the fluid and start my car ?
and when I start it, must I take any special care ?
thanks
Old Jun 29, 2011 | 03:36 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: easy question. Fill all the fluid
Fill the converter partway before placing it on the input (and rotating / pushing so it indexes to the input / stator shaft properly) and then once it's in place, add fluid via the dipstick tube. And start.
Old Jun 29, 2011 | 08:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Then drive, little bits (like in a parking lot). Drive in 1 a few feet, then in 2 a few feet, then in D a few feet, then in OD a few feet, then in R a few feet, then recheck/refill fluid, and do it again and again until you get it to correct dipstick level without adding anymore.
Then, a short trip (like around the block), then recheck/refill. Then many a feww blocks, then recheck/refill.
This is how I ended up doing mine - after an hour or so, I had the tranny full by slowly working in the fluid like that.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stryker412
Sep 20, 2015 06:59 PM
corey8084
Sep 17, 2015 02:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
Ian Irvine
Sep 4, 2015 08:08 AM
