1986 Pontiac firebird KICKDOWN CABLE HELP !
Car: 1986 Pontiac firebird formula
Engine: 383 sbc
Axle/Gears: 4th gen 3.42 posi
i have an 86 firebird that i swaped the 305 for a 350. im using the 700r4 tranny that was in there but the motor i have has a victor junior intake manifold with a holly 650. i have the spectre throttle bracket but when i try to hook the kickdown cable its way to short. i think i need a new bracket
if i pull on the cable as hard as i can i still need another inch ! what do i do ??
Guest
Posts: n/a
Re: 1986 Pontiac firebird KICKDOWN CABLE HELP !
700R-4 is TV, not just kickdown. It's far more critical, as it controls the line pressure in relation to the throttle opening. Drive without it, you'll kill the trans.
TCI makes brackets that attach to the rear 2 bolts holding the carb to the intake manifold.
You'll also need their matching bracket that attaches to the primary throttle shaft.
The Q-Jet versions won't do, you need TCI's Holley versions.
Engine: 383 sbc
Im having trouble finding these brackets on summit. but thanks for pointing me in the right direction !
Engine: 383 sbc
and could i just use this ? http://www.tciauto.com/tc/200-4r-700...-tv-cable.html
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
