91 posi disc rear into an 86 w/drum rear
Old Jul 5, 2011 | 09:57 AM
ciar623's Avatar
Car: 1986 Z28
Engine: 355
Axle/Gears: open 2.73's
I am attempting to put a posi disc rear end out of a 91 RS into an 86 Z28 with an open drum rear end. What will I need to make this conversion possible. I have looked at parts but not sure if I need them for the 86 or the 91. Any suggestions would greatly be appreciated. Thanks in advance, Mike
Old Jul 5, 2011 | 10:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 91 posi disc rear into an 86 w/drum rear
The following should provide the info you require:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 5, 2011 | 11:28 AM
ciar623's Avatar
Car: 1986 Z28
Engine: 355
Thank you
Old Jul 5, 2011 | 07:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Jack, jack stands, larger sized wrenches/sockets, maybe some brake line reflaring with correct sized connectors. It's a direct swap.
Old Jul 10, 2011 | 03:00 PM
Felix.2090's Avatar
Yeah it should be a direct swap, just make sure you don't drop the rear end on your self.. I swapped a negative drum brake rear end from my 90 RS (V6) to my 91 Z28 (V8), de-greased it and painted it, looked like new, and it works really good! Although I would love to have a posi with disc brakes, for now that will do it, I plan to buy one in the near future.. so Ii any one knows of one posi disc brake rear end for the 91 Z28 camaro please let me know thanks..
Attached Thumbnails 91 posi disc rear into an 86 w/drum rear-010711170723.jpg   91 posi disc rear into an 86 w/drum rear-010711170751.jpg   91 posi disc rear into an 86 w/drum rear-010711170728.jpg
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
novaderrik
Aug 10, 2015 12:44 PM
