700r4 1989 - Questions about Sprags
Old Jul 25, 2011 | 01:42 PM
PeterFeix's Avatar
Car: Trans AM GTA 1989
Engine: 383 HSR AFR195 JRC Cam280/286
Transmission: T56 Conversion
Axle/Gears: 3.27 9bolt
Hi all!
I'm currently building a hopefully longer-lasting transmission than my rebuilds before and in order to do that, I'll drop in some more new parts than just some new steels+clutches+seals.
I found that one element of my Lo/Reverse Sprag was missing, so I ordered a new sprag (borg warner, don't know the part number right now), which is a slightly differrent design than the original one (should be 4l65 specs). The old one has a little bit taller but thinner elements.
My problem is:
The sprag fits perfectly into the center support.
And the sprag fits perfectly around the inner sprag race (i think the "center part" is called like that ).
BUT: All 3 Parts doesn't fit in each other at the same time. It seems that the elements are pressed slightly to the center so that the inner part doesn't fit anymore.
Would it be safe to mill off the inner part by some 1/1000s in order to get it fitted in?
Or could I mistakenly have got a 82-86 Part for my 87+ Tranny? I've seen that there are differences regarding the lo/reverse sprags in those years.
Thats how it should look like when it's done.
Hope you can help me.
Thanks in advance
Alex
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
