New clutch is slipping?!
Old Jul 28, 2011 | 09:12 AM
Piston454's Avatar
Car: 1990 RS Camaro
Engine: 400 sbc throttle body
Transmission: world class t5 manual
Axle/Gears: 3.73's, Detroit TrueTrac
Hi I replaced my clutch about 10,000 miles ago when i put my new motor in, and now it is starting to slip in first when in get on the gas. The clutch pedal is literally all the way out before it starts to grab. Is there any way I can get the pedal to engage sooner?
Old Jul 29, 2011 | 01:30 AM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
Re: New clutch is slipping?!
what engine, trans and clutch do you have. did you change anything? like pedals etc
Old Aug 2, 2011 | 02:14 PM
Piston454's Avatar
Car: 1990 RS Camaro
I have a 350 tbi in it. Pushing 350 hp. And I have the stock 5 speed in there. And nothing was changed pedel wise.
Old Aug 2, 2011 | 02:23 PM
Guest
Guest
Posts: n/a
Have you checked the fluid level in the reservoir for the clutch master cylinder? Often? Have you been needing to top it off very often? Ask your last few passengers if they think you "ride the clutch".
Old Aug 2, 2011 | 02:25 PM
Guest
Guest
Posts: n/a
Also, if you did glaze the clutch, then it should be way more of a problem when trying to cruise the interstate in 5th gear.
Old Aug 3, 2011 | 02:35 AM
Car: 92 z28
Transmission: t56
did you machine the flywheel with the new clutch?
Old Aug 24, 2011 | 12:56 AM
Stebo's Avatar
Car: 1992 RS Camaro
Engine: 305 soon to be 383
Transmission: Richmond -6
Axle/Gears: 4:10 with Auburn locker
Did you have the flywheel surficed, cleaned up. Just curious?
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
