mini spool on street strip car
Old Jul 31, 2011 | 09:54 AM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
how is this car going to act
Old Jul 31, 2011 | 12:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: mini spool on street strip car
Mini spools are designed for dirt track racing or off road use where tire slip is normal. On the street with both axles locked, the tires will turn the same speed as you go around a corner. Normally with differential action, the outside tire will turn faster than the inside one because it has a longer path to take.
For street driving, this means you tires will probably wear quicker due to the scrubbing across the pavement, there may be jerking when going around corners and in poor driving conditions like rain or snow, handling may be an issue. If the tires grab while one is trying to go faster than the other, there's a chance you could break an axle.
You're much better off installing a good posi for street or street/strip use although many people have used mini spool on the street.
Old Aug 1, 2011 | 12:17 AM
Pro Built Automatics's Avatar
There are no positives here, only problems. Even at the drags tire run out has to be perfect. I don't like them or recommend them. A good posi will do everything you need.
Frozer!!!
Jan 19, 2024 04:55 PM
Reborn756
Sep 4, 2015 03:42 AM
TreDeClaw
Aug 14, 2015 06:58 PM
milk
Aug 10, 2015 06:26 PM
1nastygta
Aug 8, 2015 07:38 PM
