WC T5 FLUID SUGGESTIONS???
Old Jul 31, 2011 | 06:11 PM
MORREALE5's Avatar
Car: 1987 IROC Z
Engine: L31 VORTEC
Hello,just change trans fluid in my wc t5 and refilled with just a basic oreilly dexron 3 atf fluid.it seems like the trans is shifting alittle bit harder than before the change?i know it was atf that i drained out cause of the red color.is there a better atf to improve the shifting??is synthetic better??has anyone had the same problem but fixed it with an additive??i was reading a couple threads about people having vibration at high problems,i had the same problem.new u joints and balanced driveshft now smooth as silk thanks
Old Jul 31, 2011 | 06:21 PM
Re: WC T5 FLUID SUGGESTIONS???
No, synth won't really change the shifting. AA;; ATF is going to be pretty much about the same in that regard.
You might want to try the GM "Synchromesh" fluid.
Back "in the day", I always used to run half-&-half ATF & STP in my Muncies and T-10s; but I've never tried that in a transmission with composition blocker rings such as the 2nd design T-5 or the T-56.
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
mfp189
Sep 27, 2015 09:25 AM
