clutch not fully releasing/ not shifting
Old Aug 3, 2011 | 12:52 AM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
hey guys just got my car going after 4 years, heres my set up i hope you guys can steer me in the right direction. i have a mild 350 with a t5 (savin pennys for my tko but i wanna drive) its a non w/c with a hurst shifter and centerforce dual friction clutch on a stock flywheel. i have every gear when the car is shut off, but when its running, it doesnt seem to go into gear unless i almost force it but it doesnt move when i have the clutch in? i can start the car in gear and it doesnt move.
what im thinking is it looks like the clutch fork adjustment key is depressed in? i had this whole set up working when i had my old 305 but had stock clutch and shifter? i dont know if my missing something else? the clutch seems to be fully bleed but how else could i tell? any help would be appricated
Old Aug 3, 2011 | 05:22 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: clutch not fully releasing/ not shifting
How do you have your throw out bearing installed.
https://www.thirdgen.org/forums/tran...t-go-gear.html
Scroll to the end of that thread where there are two pictures...a right and a wrong way of installing the throw out bearing. That was most of the cause for my hard shifting. The rest of it i assume is a slight air bubble in the clutch hydraulics still.
Old Aug 3, 2011 | 12:44 PM
rs89todd's Avatar
Engine: 355 chevy
Transmission: t-5
i believe it is installed correct cause i did it wrong once and learned lesson there but could have slipped when trying to get the trans in, ill try pumping the clutch a bit more incase of air (i just filled it up when i put it together) thanks tho. but if it doesnt work i think ill just get a new throwout bearing and fork
Old Nov 25, 2012 | 12:45 PM
garthpe's Avatar
Car: 1992 Z28
Engine: 434 CI
what did you end up finding out/doing???
devilschariot
Feb 25, 2016 03:08 AM
88rscamar0
Sep 23, 2015 09:08 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
