Need some advice on a 4L60E
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
hey guys im looking to find out if there is way to see if a 4L60e out of a 95 camaro is worth getting, I know a guy parting out a 95 camaro and he is selling everything dirt cheap, he is only askin 100 for the tranny and im in the middle of doing a Lt1 swap into my 91.
So is there any way to tell before I buy and install?
Thanks in advance
Ken
Thanks in advance
Ken
Guest
Posts: n/a
Re: Need some advice on a 4L60E
Sometime during the '95 production run, the PWM lockup was introduced. Something to be aware of. I'm not in favor of it myself. I want the converter either 100% locked, or 0% unlocked, nothing in between, wearing it out. I want to feel it engage without having to watch my tach. Same goes for hearing is dis-engage. But there are kits to fix it if you get a PWM. With the kit or non-PWM, you can use any 700R-4 converter you like.
ok so should i avoid a 95 4l60e? i mean i thought a 4l60e from 94-97 would work aslong as it was connected origenaly to a lt1, or am i wrong?
im not familuar with these trannys thats why i ask.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
700-R4 will work fine. If you wanted the 4L60E because it's a cheap replacement people have done the swaps here before. I believe that year uses the same crossmember as the 700-R4. You'll find plenty of info using search.
yea i have searched, but I was tring to see if the 4l60e from this 95 z28 would work , cause the tranny is only 100 bucks, nad if i keep the 700r4 ill probley be spending a little more then 100 on getting the 700r4 towork.
Engine: 383 SBC
Yes it should work with some extra parts. That being said I imagine you would need the computer and wiring for it depending on your lt1 ecm you are using. I believe they are computer controlled.
yea i actually have the pcm for that 95 camaro, i was going to trade it for someone to tune my pcm, the wiring harness I have is from a 96 and im having someone make me one that will work with my 91, is the 96 harness the same as the 95? does anyone know
heres a question for someone, will a 4l60e out of any vehicle work that had a 96 lt1 in it? caprice, impala,fleetwood, raodmaster, etc.?
Engine: 383 SBC
I believe after '95 they used different bolt pattern and it would need a custom crossmember.
Guest
Posts: n/a
Excluding the versions for the 3.4L / 3.8L:
The '95.5-'97 4L60Es were all the same, and bolt in the exact same as any 700R-4. The '95-'95.5 4L60E's are the exact same as all the '94s.
PWM versions have an extra wire in the harness, and if you remove the torque converter, you can see PWM cast onto the pump housing.
The only possible reason to avoid the PWM versions is having to buy the lockup-fix kit. It's about $30, IIRC.
Guest
Posts: n/a
There were some changes for '98. The tailhousing went from 4 bolt to 6 bolt, and the bellhousing became bolt-on rather than integrally cast as before. One bolt got deleted from the upper right rear of the LSx blocks, but all the other holes stayed the same. And because that 1 hole got deleted, they began using the top center, which many of the old 350 blocks had drilled and tapped, but which 700R-4s didn't use.
Car: check
Engine: check
Transmission: check
HoosierinWA
Oct 7, 2015 10:15 AM
