Torque Converter Recommendation
I am getting ready to swap out the original 305, looking for recommendations for torque converter. This a new rebuild, block and heads professionally machine and short block assembled. I haven’t fired it up yet, will have to wait until I get it installed, I wonder what type of power I am looking to get?
1984 Z28 Camaro,
700H4 transmission
153 Tooth Flex Plate
3.73 auburn limited slip with
245/50 – 16 tires
Hedman 68470 Shorty Headers
1967 327 SBC
Block bored out .30 over with Speed Pro ZL2166NF30
Bore (in) 4.030 in.
Compression Distance (in) 1.675 in.
Dome Height (in) 0.125 in.
Piston Head Volume (cc) -5.30cc
CS-179R HYDRAULIC FLAT TAPPET Cam
Power Range : 2200-5200 rpm
Duration @ .050 Lift : Intake 222 Exhaust 222
Duration @ .006 Lift : Intake 290 Exhaust 290
Valve Lift : Intake .447 Exhaust .447
Lobe Centerline : 114
Fuelie Heads
2.02/1.60 valves 64cc chambers
1.6 rockers
GM Performance 10185063 - GM Performance ZZ4 Intake Manifold
Holley 4160 R3814 600 CFM
1984 Z28 Camaro,
700H4 transmission
245/50 – 16 tires
1967 327 SBC
Bore (in) 4.030 in.
Fuelie Heads
1.6 rockers
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Torque Converter Recommendation
If a street car, most look at 2400 - 3000 stall. Anything higher is generally track use.
If looking to save some cash - do a
for the S-10 converter info on here. No one mentions it much anymore these days, but 5+ years ago everyone talked about using the converter from a S-10 V6 pickup - it stalls at about 2200 rpms, and is alot cheaper to buy (or used to be) than a brand-name off-the-shelf converter.
I installed a S-10 converter in my car, and it seems to work really well, stalls right at about 2200 rpms behind my 350. Think I paid $125 shipped (but that was 5 years ago - check current prices).
for the S-10 converter info on here. No one mentions it much anymore these days, but 5+ years ago everyone talked about using the converter from a S-10 V6 pickup - it stalls at about 2200 rpms, and is alot cheaper to buy (or used to be) than a brand-name off-the-shelf converter.I installed a S-10 converter in my car, and it seems to work really well, stalls right at about 2200 rpms behind my 350. Think I paid $125 shipped (but that was 5 years ago - check current prices).
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
dont go by word of mouth on this one, like alky(that man is pretty smart
said to much stall can be just as bad as not enough. you really should be making your choice based on your cam for the best match up. id contact the cam maker. i used the 268 voodoo cam and i let them decide my best stall and its a great match up i'm extremely happy with it. as far as brand... well thats gonna come down to opinion and well..... ya know lol $250 to spend on it though shouldnt be a problem i think i spent $190 on mine from ebay, it was a tci if i remember right.
just my 2 cents
said to much stall can be just as bad as not enough. you really should be making your choice based on your cam for the best match up. id contact the cam maker. i used the 268 voodoo cam and i let them decide my best stall and its a great match up i'm extremely happy with it. as far as brand... well thats gonna come down to opinion and well..... ya know lol $250 to spend on it though shouldnt be a problem i think i spent $190 on mine from ebay, it was a tci if i remember right. just my 2 cents
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
i ran that cam years ago in a 305. pulled good in midrange and up but was a dog down low listen to these guys 2500range should be good. i ended up pulling that cam out for the summit 1103 and never looked back.
Ragtop Man
Sep 12, 2015 12:23 AM
