700r4 clutch material ?
Old Aug 26, 2011 | 01:40 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
I am getting ready to rebuild a 700, and I ordered a rebuild kit. It was a "performance" kit with steels, frictions & a seal kit. When it arrived it had Alto red clutches & Kolene steels. It also had the 3-4 power pack with 9 thin red clutches and thin steels. From some research I did, the general conscious is that this setup doesn't work very well in the 3-4 clutch pack. So I ordered a Raybestos Z-Pack for the 3-4. What I'm not very clear about is, will the red clutches be OK in all of the other areas. I know I'll need a few hard parts also, but my concern for now is the clutch setup. BTW the trans will be used in a truck. Mostly daily driver with a very little bit of towing. I'm not new to trans work. I don't do it for a living, but I keep up a few drag cars for some local guys. The red clutches work very well in the Powerglides I build. Any other tips on this trans will be much appreciated. Thanks in advance, Dean.
MrPackstin
Oct 25, 2017 08:09 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
