Flexplate and Torque Converter
Old Aug 31, 2011 | 07:07 AM
30reddogs's Avatar
Car: 1987 Camaro
Engine: 350 5.7 TPI
I am in the middle of a transmission swap i got everything pretty much done however i cannot get the flexplate and torque converter bolt holes to line up. i have done this before and have not had a problem rotating the torque converter or the flexplate. However in this case (a different new to me 700r4 transmission) i cannot rotate either. the torque converter rotated freely when the transmission was on the ground. i tried rotating the flex plate at the torque converter and from the front of the engine no dice in either instance. the engine has not been started since i blew the old transmission a few weeks ago would this effect anything?
any ideas?
Old Aug 31, 2011 | 07:29 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Flexplate and Torque Converter
You have the engine and tranny bolted to eachother, correct- not just lined up?
Pull your spark plugs- that makes it easier to rotate the engine.
Also, make sure the gear selector lever is in P or N.
Old Aug 31, 2011 | 08:46 AM
30reddogs's Avatar
Car: 1987 Camaro
Engine: 350 5.7 TPI
Yes the engine and transmission are bolted together. I had the tried both P and N and still no dice. I did have not tried taking out the spark plugs though ill give that a try
thanks
Stangski09
Nov 14, 2015 01:27 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
roysatikas
Sep 7, 2015 08:08 PM
