Need a little help
Old Sep 12, 2011 | 09:30 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Need a little help
First off, I know barely anything about rear end gears, so what's the difference between bolt ring and pinion set and excel ring and pinion set? And will 3.73's be good with a 305? Or not any better than 3.42's?
Old Sep 12, 2011 | 09:42 PM
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: Need a little help
I have asked part of this question. 3.42s are good for a 5.0. Most people who did 3.73s said that they would rather have done 3.42s. As far as the other stuff goes I'm still furing all this out my self haha.
Old Sep 12, 2011 | 09:49 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
But is having too high of gears a bad thing? Because if not then I don't really see the difference but like I said, I have barely any knowledge of this
Old Sep 12, 2011 | 10:17 PM
Car: 1992 Camaro RS
Higher Gears generally means less MPG for one thing. But some state that not having to lay on the peddel to get up to speed evens it out.
Old Sep 12, 2011 | 10:27 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
That's true, I think I need to know more about the difference between bolt ring and excel ring first, then pick the ratio depending on the plans for my car
Old Sep 12, 2011 | 10:33 PM
Car: 1992 Camaro RS
Should be some stuff if you click HOME and head to the tech articles or FAQs
Old Sep 12, 2011 | 10:35 PM
Car: 1992 Camaro RS
Yup. Just look at Tech articles, go way down past engine and carbs/efi. And click GEARS.
