help with gear selction
Old Sep 20, 2011 | 07:39 PM
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
hey guys lookin for a little advice on gear selection for my 86 TA. it has a 383 dart 215 platinum iron eagles comp cams xs290 540" in 558 ex 252 260 dur @50 on a 110ls 850 holley with a victor jr. th400 w/ 3000 stall and tire size is 245/50/16 and slicks are 26/9/15. i was wonderin if i should go with a 3.73 or just put a 4.10 in it. it is a street car that will see trips to the track just seeing what guys with similiar combos are runnin. and it is the stock rear with 2.73 so i know i need the fatter ring gear. thanks alex.
Old Sep 20, 2011 | 08:25 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: help with gear selction
373 would probably be best if your going to drive on the streets. dont think the 10 bolt will last long though
Old Sep 20, 2011 | 08:46 PM
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
yeah not countin on it to last long just hoping it will until i can save up for a 9" or maybe a 12 bolt. do ya think a 3.73 will leave some performance at the track
Old Sep 20, 2011 | 10:46 PM
brando278705's Avatar
Car: 1987 Camaro IROC-Z
Engine: 5.7
Axle/Gears: 3.70
3.73 will run good on the track too. 3.73 is a solid gear. My buddy has one and it runs low 11's and got into the high 10's and his engine is only hopped up a little bit.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
