t56 question
Old Sep 24, 2011 | 03:37 PM
porkenstein's Avatar
Car: 91 RS Convertible
Engine: LSA
Transmission: 6060
Axle/Gears: 373
t56 question
I know this has been covered a million times and I have read so many links but I still need to know which t56 to buy. I have read that the retrofit bolts right up but I am installing a ls3 so I am guessing that's not the one I want. I am planning on buying new so if you could explain to a not very mechanical person it would be appreciated. Thanks in advance.
Old Sep 24, 2011 | 05:02 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: t56 question
If you want one to work with a SBC/T5 setup now, and a LSx later, then get a LS1 Fbody (98-02) or GTO T56 and use the adapter plate. http://www.thegearbox.org/catalog/it...17/4803441.htm
If you're going LSx right now, just forget the adapter plate.
You'll have to work out the driveshaft/torque-arm/Xmem/speedo with the adapter.
Old Sep 24, 2011 | 09:20 PM
Engine: LSA
Transmission: 6060
Axle/Gears: 373
Re: t56 question
No I am doing it all at once. lsx engine and t56 transmission at the same time. This car is only used for play so doesn't matter how long it takes to finish so figured If I did it all at once it would actually save work and money. Wasn't expecting that answer on transmission choice. Thanks
Old Sep 25, 2011 | 08:05 AM
85MikeTPI's Avatar
Re: t56 question
So you just need one for a LS1 Fbody (98-02) or GTO T56. Don't get one that's listed for an LT1 or from the ('93-'97) Fbodies.
There's nothing wrong with buying new, but you're getting a stock transmission at a new price. Very little wear happens in a T56 besides the items that get replaced during a rebuild, so you lose nothing buying a well-built rebuild.
FWIW, I have a LS1-style T56 in the classifieds now.
https://www.thirdgen.org/forums/engi...body-32-a.html
I have one of these going behind my LS3/L92 going into a '92 vette.
19irocz85
Aug 26, 2015 07:54 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
